Video Card wont Detect 2nd monitor
Blu3Jay
I have a rx 560 in my machine with a hdmi cable going to one monitor and a dvi cable going to the other, i had both monitors running fine then until today i restarted my machine and the other monitor turned off for good.
I've tried EVERYTHING.
reinstalling and uninstalling with DDU and AMD software.
Using intergrated graphics.
unplugging the card and plugging it back in.
i've tried google, youtube and nothing is giving me what i need.
Any help would be very awesome!
So the monitor doesn't work? maybe it broke. Have you tried it by itself?
Primary PC:
no my gpu wont detect the 2nd monitor, when i try to detect it in windows settings it doesn't appear
EDIT: yes the 2nd monitor works
So it worked with integrated or no?
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
Yes it did
22 minutes ago, Blu3Jay said:
Yes it did
So have you tried other ports on the card and other cables?
