HP H220 SAS controller woes
Solved by leadeater,
1 minute ago, Sauron said:In case it's relevant, I installed centos on a drive while I was waiting for the second cable to arrive - it boots with a single cable but not with two. Could it just be grub being picky?
Sounds like it, might be a case of the bios changing the primary hdd on you when you change drives (add/remove), that would prevent the bios from seeing grub at all and breaking booting.
Featured Topics
Marie Rose ·
Posted in Power Supplies0 -
3
2
3
7
9
Tamgam12 ·
Posted in New Builds and Planning6 -
remo233 ·
Posted in New Builds and Planning22 -
5
6
