What CPU
What motherboard
What power supply
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/971073-help-please/#findComment-11744590
15 minutes ago, Newbiebuilds said:
Okay. So I bought a new CPU , and just now a new power supply, what is the problem with my pc?! It turns on for a few seconds, CPU led turns on once right before shutting my whole thing down...
Sounds like when your old PSU blew up it killed both your motherboard or CPU, possibly both.
Good luck my friend. At least try clearing CMOS first.
https://linustechtips.com/topic/971073-help-please/#findComment-11744609
26 minutes ago, Newbiebuilds said:
Hey it turned on, boot device led is lit... Sorry to bother, what can my next problem be? I'm completely new to this.
Take everything out of the case and see what happens booting on top of a box, might be a short in the case
https://linustechtips.com/topic/971073-help-please/#findComment-11744654
CX750m have a pretty high failure rate at work. No idea why, but the 650 and 850 tend to last much longer. I'd swap it out if you are still within the return period.
As for your problem, yeah, the hard drive isn't showing as connected or powered. If you assemble everything outside the case to make sure it all works first it'll be much easier to diagnose errors.
https://linustechtips.com/topic/971073-help-please/#findComment-11744708
