I keep on seeing on amd and Intel cpu s that it has a max boost clock
like on the ryzen 5 1600 it says it has a max boost clock of 3.6ghz if I go over said max boost
will it damage my cpu
is it safe to go over
what will happen and what are the restrictions i will encounter if I go over
https://linustechtips.com/topic/970744-max-boost/
You can go over, but if you go too far you'll overheat and introduce isntability. As with any overclocking, it's all about a combination of higher clock AND stability.
https://linustechtips.com/topic/970744-max-boost/#findComment-11741496
The boost clock is the officially supported/integrated clock boost (overclock in a sense). assuming something isn't forcefully limiting this (thermals, clock boost disabled, ETC) your processor has the potential to run at this frequency when under load.
To manually overclock, you're going to need an unlocked chip, one that support modifying the clock speed. Overclocking beyond listed speeds carries the risk of irreversibly damaging your hardware, as well as software instability, but can be done relatively safely so long as you gather an understanding of what you're doing first. (I.E. Google  overclock (insert processor here) guide, watch a few videos, read a few written guides)
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/970744-max-boost/#findComment-11741518
