ticking noise when connected to router
Solved by intender,
when you first connect a drive to the router its going to index the files. this will usually take anywhere from 10min to 45min depending on the size and speed of the drive and how full it is. also you can look in your router to see if it has indexing options or also options to let the hdd spin down and sleep after a while. A lot of routers will keep network drives spinning pretty much all the time by default.
Featured Topics
xJDL ·
Posted in Troubleshooting1 -
Marie Rose ·
Posted in Power Supplies8 -
7
4
7
14
10
Tamgam12 ·
Posted in New Builds and Planning6 -
remo233 ·
Posted in New Builds and Planning25 -
5
