Posted September 3, 2018 Does anyone know of a good wireless security camera system that will record at 1080p upon motion detection? There have been quite a few thefts and damages to property in my area that needs to stop. I'm not looking to spend a fortune on this system but I'm willing to put a little money into it if needed. I need cameras that are capable of reaching the receiver up to 50ft. I need these cameras to be outdoor proof have night vision and for them to be completely wireless. I would prefer recording to happen about 30 seconds before motion detection and until motion is no longer detected. Cloud services are not a requirement but email or mobile notifications are. Thank for in advance if anyone has a solution for me. Link to comment https://linustechtips.com/topic/967834-wireless-security-camera-system/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 3, 2018 No budget, no one can really help. I already suggest hardwire if possible, after using/install wifi cameras there is only a few brand that is reliable and in most case you need to upgrade their existing wifi infrastructure as most people are using ISP all in one routers/ap and has pretty shit range and reliability. If you want something easier is go look at UniFI cameras and software/nvr can run on pretty low spec computers. Magical Pineapples
