Hello all,
I need to pick your brains.. I’ve been on this project for a few days now changing out a bunch of stuff in my build.. and now I’m trying to start everything up but I won’t get any video output. I’ve checked my CPU sockets, no bent pins, nothing was apparently damaged, I’ve tried replacing the CMOS battery, and still no post beep.. I’ve tried just about every “common troubleshooting steps”. Yes the cables are correctly connected, and my motherboard is less than a year old since I bought it (Z270F strix). I’ve fried my brain at this point. Any suggestions?
https://linustechtips.com/topic/966858-no-post-help/
What exact specs do you have? Especially CPU?
https://linustechtips.com/topic/966858-no-post-help/#findComment-11704991
Does any LED Light in the computer come on? Since it might be that your gpu supports DisplayPort and your monitor supports HDMI (dumb me had learned that)
With Great Power, Comes a Great Electricity Bill
Main
Setup: Intel core i5-8400 (OC'd), MSI Z-370-A Pro, Crucial Ballistix 8GB, Be Quiet! Pure Slim, Cooler Master Masterbox Lite 5 RGB, TP-Link Wifi Adapter, ASRock RX580, Artic Silver 3.5g Thermal Paste, Logitech G105, Logitech M310, Razer Sphex V2 (Mat), EVGA 500W 80+ Silver, 1TB WD Blue, 240gb Kingston Digital
https://linustechtips.com/topic/966858-no-post-help/#findComment-11705099
Yes there are LED lights. I am not expecting video output, the system won't even pass POST.
The weird thing here is that after one night the system just stop working
https://linustechtips.com/topic/966858-no-post-help/#findComment-11705108
Have you tried to reseat your ram? Or maybe take it out and clean off access things it caught on?
Main
https://linustechtips.com/topic/966858-no-post-help/#findComment-11705113
Yes, I did that. I think my mobo may have just died.. I took compressed air and carefully cleaned the entire system so there’s no dust in the DIMM slots.
https://linustechtips.com/topic/966858-no-post-help/#findComment-11706213
