So my brother needs a new pc. He needs the cpu power for graphics design and stuff like that. He rarely plays games, and when he does he only plays age of empires and roller coaster tycoon.
I am in Hungary so i can't use pcpartpicker. His budget is 110000 HUF or around 525 dollars. I get the parts from this ( http://www.pcx.hu/ ) website usually
Parts:
cpu:Intel core i5 4440.
Case:Cooler Master n200
mono:Gigabyte b85m-d3v
memory: 4GB kingston hyper x. Plan to upgrade to 8GB
storage: WD caviar blue 1TB
psu: corsair cx430
And maybe a discreet graphics card in the future. but that is out of the question now.
Thanks for the help.
Intel core I5 4460, Gigabyte H97M-HD3, Gigabyte gtx 760, 8 GB corsair value ram, Thermaltake core v21, Thermaltake Smart 630W PSU
Alcatel OneTouch D5... IT WORKS!!
http://pcpartpicker.com/p/BxMjTW
https://linustechtips.com/topic/96679-light-gaming-need-the-cpu-power/
Thats pretty good man! Later on you might look for an i7. i7 single thread horse power will be needed for graphic design. Just dont OC and stuff and that should hold!
Main Rig: White Lightning  = -Intel Core i7 3770 (4.1Ghz)-Zalman CNPS12X-MSI Z77A-G45-16GB G2 Patriot-MSI GTX 660TI OC PE-Corsair 650W-Corsair 600t White-
Laptop: MSI GT60 = -Intel Core i7 4700MQ-MSI GTX 770M-
Peripherals: Corsair K90-Corsair M90- Corsair 2100-CM Storm Quickfire TK (Green Switch)-Logitech G700
Not really...
@Abel225 You'll need a discrete graphics card for acceleration if you're doing any serious graphics design.
What programs are being used?
Not really...
He is studying in a university. He won't use graphics design programs for now. He'll use autocad civil3d. and more autocad software. So the videocard can wait for atleast a year.
In that case, your current plan looks fine. I'd look into getting a cheaper mobo--literally any 1150 mobo would do.
