Using SSD as a flash drive
Go to solution Solved by Enderman,
3 minutes ago, Bobulous_91 said:
How do I do that?
https://www.computerhope.com/jargon/d/diskmana.htm
You right click.
I got my brother a 128GB SSD for Christmas a while ago because he needed upgrade space, but he forgot about it and never used it. This was a few years ago, and I bought a SATA III to USB cable which I though would work to let it be used as a USB flash drive if he wanted. I found the SSD and the cable and he didn't want them, so I tried to use it as a USB flash drive since I only have a laptop. It won't work. It doesn't registor in my documents or anything, or notify me when I plug it in. I am 100% sure my brother never used it as a hard drive, so I was the first person to plug it into anything. Is there a way to make it work so I can store files on it?
https://linustechtips.com/topic/966638-using-ssd-as-a-flash-drive/
Windows disk management.
Make a new simple volume in the unallocated space.
How are you powering the SSD?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
How do I do that?
You right click.
