Hey guys, I have an unknown program running in my PC, using a lot of CPU and I'm afraid it's some sort of Virus or Miner.
YOU CAN SEE IT HERE
Then, when I'm going to the file location it opens this:
YOU CAN SEE IT HERE
Even though I probably shouldn't try this, I've tried to delete it and I have no authentication even though I'm the only owner.
What can I do?
~Leo
https://linustechtips.com/topic/966588-unknown-cpu-usage-program-please-help/
I had this problem with svchost before, did you recently updated your BIOS?
// EDIT
+ If not and it could possibly be a virus, try backing up important stuff such as images, game configs, project files, and do a complete OS reinstall.
twitch.tv/oliv_r
Like @oliveirarui sad svchost can be bit buggy some times
It can be a miner but i doudt it as its not ussing a any of your network. Als can you tell the cpu is runnen high than normal ( is it getting wormer ar the fans spinn louder ect)
@Origami Cactus right to left form read the in Israel. you left leaning speaking....
"i reject your reality and substitute my own"
          --- Workstion --- GamePc ---
"College great Dropout Engineering"
5 minutes ago, Oliv.r said:
Just in a different lang. Cmonbruh
Its mirrored, my dude
EDIT: Damn, guess I need to be more cultured
Thanks for the help, it's indeed Hebrew.
What can I do if it's not a virus and such?
Can I fix it?
And I never had it before, started in the last week, cpu indeed working harder.
~Leo
10 minutes ago, manikyath said:
run malwarebytes, run an antivirusscan of choice, if those both come up empty chances are fair it's a software issue, rather than malicious software
// EDIT
23 minutes ago, Origami Cactus said:
Run malwarebytes.
On a side note, wth is wrong with your task manager?
Guys I can't download "malwarebytes" - everytime I'm looking for it in Google, chorme crash. It's weird.
~Leo
Try microsoft edge or internet explorer?
I only see your reply if you @ me.
7 minutes ago, Oliv.r said:
Of the virus? I wish. I don't have or even know about it. I was joking.
4 minutes ago, Origami Cactus said:
https://downloads.malwarebytes.com/file/mb3/
If you open the link it should start downloading straight away.
Can't install, the installer gets crash too.
~Leo
Can you reinstall windows, and use malwarebytes+antivirus the next time?
Just backup your important stuff before.
