i9 9900K pci lanes small question
Solved by Lurick,
8 minutes ago, djboy6480 said:"Up to 24" <-- If your CPU can provide the PCIe Lanes
You do realize those are not CPU lanes right?
The CPU is connected to the CHIPSET via DMI lanes and the chipset can provide additional lanes above and beyond the CPU. They aren't as fast since all 24 lanes are are limited to a combined total of PCIe 3.0 x4 bandwidth which is the speed of the DMI link back to the CPU.
Further example:
