I already solved this but just to make sure. Can you turn on a MSI Z370-A Pro Motherboard with a screwdriver? Because I could not do it. I could do it on another motherboard though.
With Great Power, Comes a Great Electricity Bill
Main
Setup: Intel core i5-8400 (OC'd), MSI Z-370-A Pro, Crucial Ballistix 8GB, Be Quiet! Pure Slim, Cooler Master Masterbox Lite 5 RGB, TP-Link Wifi Adapter, ASRock RX580, Artic Silver 3.5g Thermal Paste, Logitech G105, Logitech M310, Razer Sphex V2 (Mat), EVGA 500W 80+ Silver, 1TB WD Blue, 240gb Kingston Digital
https://linustechtips.com/topic/966247-common-problem-or-not/
Yes you can.
You have to make sure youre bridging the right pins
https://linustechtips.com/topic/966247-common-problem-or-not/#findComment-11699308
probably, as long as it has powerbtn pinns in not insaine possitions this should be fine. i generally just take the screwdriver and run it up and down the entire row untill the system powers on tbh
Builds:
https://linustechtips.com/topic/966247-common-problem-or-not/#findComment-11699342
