Sleek, simple case Suggestions
Solved by TVwazhere,
3 minutes ago, valhalla540 said:So basically a case that looks like an NZXT but with 3, 4 preferable (3 for HDDs, and 1 for SSD hot swap) 5.25 inch front accessible bays.
Many new cases have moved away from 5.25" bays and Hot swappable bays in general. You might be able to do something like this in a Stryker SE (updated Full Tower case) and get a lot of 5.25" to 2.5 or 3.5" hot swap coversion bays.
https://www.newegg.com/Product/Product.aspx?Item=N82E16811119334
If you only need to swap maybe a few hard drives and keep some more permanently attached, there's always the Enthoo Pro TG
https://www.amazon.com/dp/B078K32G27/?tag=pcpapi-20
If you're okay with giving up Hot swapability, the Define R6 can hold 11 HDD's and multiple SSD's
