I've been looking at several brands Corsair, Thermaltake etc., I know what I want (I'll list specs below), but it seems there are too many brands and fans to look through. Not really interested in Noctua.
Looking to pickup 3 fans
dBa: 0 - 35 dBa is fine
CFM: 70+
RPM: 1500 - 3000
140mm & 120mm options (the 120mm fans will be used on a rad later on so high static pressure is a plus)
Is there anything specific I should be looking for as well as opposed to what was mentioned here?
https://linustechtips.com/topic/965811-fan-shopping/
Be Quiet Silent Wings?
https://linustechtips.com/topic/965811-fan-shopping/#findComment-11695139
I'd ignore CFM and dBa numbers provided by manufacturers: none of the testing is standardized, so you can't really compare these numbers between brands.
For case fans, on the budget end, I'd go for Arctic F12/F14 PWM fans, on the mid to high end I'd go with Corsair ML maglevs (I know they're not really maglevs, but they're okay fans).
For radiators I'd go with either Nidec GentleTyphoons or Scythe Grand Flex.
As a general rule for fan bearings:
Sleeve Bearing: Cheap and quiet, doesn't last as long
Double Ball: Loud(er) and very durable
Fluid dynamic: Basically a higher quality sleeve
Rifle: Somewhere inbetween DB and SB
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
https://linustechtips.com/topic/965811-fan-shopping/#findComment-11695207
What are your specs and where are the fans being used?
Where are you shopping / located? Budget?
Why no Noctua?
https://linustechtips.com/topic/965811-fan-shopping/#findComment-11695593
I can spend anywhere between $20 - $30 USD.
I was leaning towards the Corsair ML, they seem to be popular, but at the same time aren't really recommended, not sure if it's like a Noctua over-hyped/same as every other fan thing. Also don't care much for RGB.
The Scythe look good for airflow as well. But are they more geared towards rads? Also aren't the Nidec Gentle Typhoons discontinued?
Why no Noctua?
Newegg/amazon/anywhere 20 - 30 USD
Noctua is overpriced and hyped.
https://linustechtips.com/topic/965811-fan-shopping/#findComment-11695835
ML's perform very well but there are quieter and cheaper fans.
Nidec GT's are discontinued but still available online and excellent for just about everything and not just rads. Grand Flex on the other hand aren't as good as Scythe's other offerings and it's not surprising when you look at the strange blade design. http://www.silentpcreview.com/article1361-page5.html
Hype doesn't change the product. Noctuas aren't necessarily much more expensive than other options. Their Redux line are excellent and often competitively priced by cutting down on accessories and packaging. As far as the NF-A12x25 is concerned, it might be the only fan that can straight up be called 'the best'.
https://linustechtips.com/topic/965811-fan-shopping/#findComment-11695892
2 intake front, 1 exhaust rear. Replacing fans that came with the case. ASRock B350 Pro4 AM4 / 1700x
I agree their redux is cheaper, but not many options compared to better priced comparable NF mainline Noctua fans.
https://linustechtips.com/topic/965811-fan-shopping/#findComment-11695991
What case? No graphics card?
https://linustechtips.com/topic/965811-fan-shopping/#findComment-11696043
2 minutes ago, StaticCPU said:
Fractal design mesh C, 1070 TI.
The stock GP-12 X2's are already pretty good. Why do you want to replace them?
https://linustechtips.com/topic/965811-fan-shopping/#findComment-11696117
Do you know what rad you're using later?
https://linustechtips.com/topic/965811-fan-shopping/#findComment-11696311
52 minutes ago, StaticCPU said:
I won't be using more than 60mm thickness radiators most likely.
If you're going with 60mm, fpi is generally pretty low and you don't actually need that much static pressure for good performance. For example, the UT60 with 10 fpi performs pretty well between the extremes of the NF-S12A, NF-P12, and NF-F12: https://www.computerbase.de/2016-04/luefter-radiator-statischer-druck-test/4/
NF-S12A's do have a surprisingly respectable amount of static pressure for its design though.
NF-P12's are great and hard to go wrong with: https://pcpartpicker.com/product/VNBTwP/noctua-nf-p12-redux-1700-pwm-708-cfm-120mm-fan-nf-p12-redux-1700-pwm
If you still want to avoid Noctua, Vortexes are similar: https://pcpartpicker.com/product/TG9KHx/cougar-case-fan-cfv12hpb
For front intake, PW2's are good: https://pcpartpicker.com/product/wj8H99/be-quiet-pure-wings-2-140-612-cfm-140mm-fan-bl040
TY-141's are better if you don't mind the color: https://pcpartpicker.com/product/tFzv6h/thermalright-case-fan-ty141
https://linustechtips.com/topic/965811-fan-shopping/#findComment-11696783
