Evga G3 750w audiable buzzing, system is not even on
Solved by Guest,
29 minutes ago, Ross Scarlet said:Haha no the switch is on just the system isn't turned on.
Then the PC is still on. It's in standby.
The PSU is still providing power, via +5VSB.
Could be that your +5VSB load is right where the PSU's transient filtering components or +5VSB circuit are creating harmonic frequencies in the audible range.
A "quick and dirty" troubleshoot would be to unplug the 24-pin from the motherboard (while the PSU is still on, but the PC is in standby, of course) and see if the buzz goes away.
