Looking for advice on wired setup
So If possible I'd like to hook my PC up to the router via wire rather then wireless if possible.  The problem is that I'm quite far from my router and I'm not sure 100ft cable would reach with the route I'd have to take to keep the cables out of sight.  So how would I go about getting cables to reach my system?  Is there a box I could buy that would repeat the signal without reducing quality?
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/96467-looking-for-advice-on-wired-setup/
Most Ethernet cables have a roughly 100m rated length so you should be fine if you want to go over 100ft.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
So what if i needed 200ft, that still going to be ok?
That's around 65-70m so yes.
Oh right Meters! duh ... lol.  Ok now just need to find a good place to get a long length cheap in Canada.
You can get it in reels, it would be a lot cheaper and easier to install than buying a ready made cable
Yea that's what i'm looking at now.  Hmm can probably get the electrician that does our electrical work at work to give me a custom length for cheap.
You should probably use him to install it as well. Check your home insurance. If the cable is improperly installed and doesnt follow your countries codes you could invalidate your insurance.
