Need Some help with a Powered USB hub
Solved by Thomas CG,
1. No it should be fine as the drives will not be writing data while the laptop is powered off, only spinning.
2. Not if you do a full shutdown
3. I don't think there is one if the hub doesn't show as it's own device you can eject.
Featured Topics
2
4
18
2
JFRStudent ·
Posted in Photography and Videography1
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
