New Ryzen 5 build, no display issue...
Solved by Spotty,
Just now, EIijah said:Yeah typo sorry, motherboard only has one pci slot, however I can test the gpu in my rig
Do that so you can rule out whether it's the system or the GPU.
Also try removing one of the memory sticks and seeing if it will boot with just 1 stick. Try different slots and swap the sticks over to give the other stick a try to see if one of the sticks may be bad. (or if you have extra RAM not in use just swap it out to see if it will POST)
After that if it still won't turn on and the GPU is working properly in the other machine, I'd recommend inspecting the CPU pins for any damage. Also just remounting it might help.
