7700HQ throttles to 800MHz but wont climb up when temps decrease
4 hours ago, JimVekemans said:why does it stay throttled after dropping in temperature?
Poor design. Dell and many other manufacturers have been producing laptops with severe throttling problems for the last decade. People put up with poor performance until the following year when the next latest and greatest model comes out. Review sites are guilty because they avoid talking about throttling. They do not want their main source of ad revenue to disappear.
Is severe throttling like you are experiencing necessary? Of course not.
Using ThrottleStop, there are a couple of settings that might be able to help you out. Open up the TPL window and enable Speed Shift. Go back out to the main screen. SST should be lit up in green. Set the Speed Shift EPP value to 0 for maximum performance. Yes, it can be adjusted on the main ThrottleStop screen.
Next, disable BD PROCHOT. This is a signal line to your CPU. It is often times used to throttle CPUs down to their minimum speed, 800 MHz. When this happens, it might get stuck at this speed indefinitely. Turning off BD PROCHOT blocks these throttling signals from getting to the CPU. There is no need for this throttling.
Along with some under volting, the above is usually all you have to do. If you are still having problems, you might want to look into disabling, removing and blocking Windows 10 from installing the Intel Dynamic Platform and Thermal Framework (DPTF) driver. Use Google to find out more about this topic. It is another horrible piece of cancer software designed to kill the performance of modern laptops. There is no need for this driver to be installed on any computer.
