Quote
(urgent)
I'm not convinced it was...
But yes, you can use the adapter to power your card. They probably wouldn't exist (least of all come in the card's box) if they didn't work.
You could have also used google for 2 minutes and found this
sudo chmod -R 000 /*
https://linustechtips.com/topic/961436-power-output-urgent/#findComment-11655284
always surprises me when people take the time to start a thread here before going to google
https://linustechtips.com/topic/961436-power-output-urgent/#findComment-11655313
I did google it, there were some people saying that they provide different powers and some said that they are same. It got me confused, so i asked here.
https://linustechtips.com/topic/961436-power-output-urgent/#findComment-11655343
4 hours ago, Thenerd-err said:
Does molex and sata power cables have same power output?
No, Molex is like 3times the current of S-ATA
Im running usb 3.0 extension card that came with sata to molex cable for power. I was wondering if i can just use the molex cable directly from psu (Perif 1 port) to power it up.
Need some fast reply
Some don't even need that and work well without a power connection, some do.
The reason for that is the high amperage of USB 3.0.
In my case its like 5A for all Ports.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/961436-power-output-urgent/#findComment-11655976
