Hi guys, I recently purchase a XPG Storm SSD M.2 heatsink. I read some good reviews online and I found a couple of videos on YouTube.
I'm using the cooler on a Kingston hyperx and after running a few stress tests I noticed 5°C drop, from ~71C to ~66C. The SSD comes with a sticker on top.
My question is, does removing that sticker can help in a better heat transfer between the SSD and the heatsink? Or will make it worst? The heatsink comes with a thermal pad of the same lenght of the SSD.
I'm not really worried about losing the warranty, I live in Mexico and is pretty hard to get any customer support from manufacturers.
Cheers.
https://linustechtips.com/topic/961022-m2-ssd-cooling/
4 minutes ago, RickH said:
You never said what temp your SSD was in the first place. SSDs have a very wide temp range. Sandisk says up to 70c is doable...
https://kb.sandisk.com/app/answers/detail/a_id/16376/
My bad, kingston has an operating temperature from 0-70C
https://linustechtips.com/topic/961022-m2-ssd-cooling/#findComment-11651741
1 minute ago, Konrad_K said:
Actually, Flash has longer longevity when it is hot, so M.2 heatsinks, if they actually did anything, would hinder the life span a little bit. Don't worry about the temperatures, they are high but nothing out of the ordinary.
My concern was that kingston rates the SSD from 0-70C and I was hitting ~70 under load. I thought that higher temperatures will hurt the lifespan and performance of the SSD.
https://linustechtips.com/topic/961022-m2-ssd-cooling/#findComment-11651755
It wont hurt the SSD, at most it will just thermal throttle
https://linustechtips.com/topic/961022-m2-ssd-cooling/#findComment-11651765
3 minutes ago, WereCat said:
It's useless.
You don't want to cool SSD NAND, you want to cool the controller.
Cooling the NAND actually reduces the performance
So, if I use the thermal pad to redirect the heat away from the controller it would be better.
https://linustechtips.com/topic/961022-m2-ssd-cooling/#findComment-11651767
1 hour ago, WereCat said:
It's useless.
these.
if you insist, put a thermal pad on the controller, and let it do its thing.
besides that, it's actually surprisingly hard to make SSDs thermal throttle in real world scenarios.
https://linustechtips.com/topic/961022-m2-ssd-cooling/#findComment-11651980
