Hi everyone!
I just watched Linus' video on bottlenecking, and was sorta afraid that my planned upgrade will bottleneck my GPU badly.
So, atm I have a i5-6600 on a asus h110i-plus d3 motherboard, with 2x8 GB ddr3 ram modules. On that, I have a zotac gtx 970 4gb GPU.
https://linustechtips.com/topic/960902-will-i-bottleneck-after-upgrade/
2 minutes ago, Darathorn said:
Hi everyone!
Welcome to the Forum!
What is your planned upgrade?
Probably a GPU upgrade, but OP, I'd suggest a CPU upgrade, first. Get a used 6700(k).
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
The 2600X will not be a bottleneck for the 970. In fact it's more the other way around (slightly).
A 2600X and a GTX 1070 makes for a well balanced rig.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
Will my poor 970 get bottlenecked?
Your 970 will be fully capable of its max performance. It will not be bottlenecked.
So a gpu upgrade wouldn't be necessary, but a 1070 would be more balanced?
I also edited my post, seeing the mistake in my post, when I meant to write that my 970 would probably botteneck.
Yes a 1070 would be a great upgrade.
Do you think my 970 is bottlenecked by my cpu, with my current build? I, rather surprisingly (imo), experience severe frame drops in a game like overwatch. I can't figure out if it's my cpu or gpu!
In your current build, probably not.
what's the usage of gpu and cpu? what's the vram usage while gaming?
not every performance drop is a bottleneck, don't overuse the term
EDIT could also be a problem of using ddr3 ram with skylake which isn't optimal
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
