Is it safe to leave side panel of case open?
gg2me
So basically I picked up an RX 580 8GB and it doesn't completely fit my case. The side panel can't be screwed on essentially. So, improvising, I just draped a towel over the side of the PC. Is this safe, or would I be better off just leaving the side panel exposed? So far the GPU is running anywhere from 60-75 C in PUBG and the CPU is running at 50-55 C.
Those GPU temps are kinda hot although safe but leaving the panel open is fine although stuff can get in it
I mean test benches are open air soo xD
poop
i'd just leave it off. just don't throw shit at it in frustration.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
Let me guess ... the cables are interfering with the side panel?
Perhaps you could create some clearance where needed by taking a Dremel to the side panel.    Not the most elegant solution, but better than having the entire case open.
Those GPU temps are normal as RX 580s pretty much keep fans at minimum unless they hit their temperature target (default 75C).
CPU: Ryzen 7 5800X Cooler: Corsair H100i Platinum SE Mobo: Asus B550-A GPU: EVGA RTX 2070 XC RAM: G.Skill Trident Z RGB 3200MHz 16CL 4x8GB (DDR4) SSD0: Crucial MX300 525GB SSD1: Samsung QVO 1TB PSU: NZXT C650 Case: Corsair 4000D Airflow Monitor: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
You can leave it open as long as you don't smoke in the room and your room is clean and not Dusty and you should be good
 But if you leave it open for a long period of time like a month or two and will collect more dust
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
