Which language will help be design this idea.
Solved by WanderingFool,
Just adding a bit onto what I said earlier...a prizes excel sheet would be easy.
Column A: List of PrizesColumn B: # of each item (e.g. A1: Gold B1: 10, A2: Coal B2: 5....Gold shows up 10/15 times and Coal shows up 5/15 times). If you are more conformable with % then take a % and multiply by 100e.g. Gold at 50% = 5000Coal at 10.5% = 1050Diamond at 20.5% = 2050Topaz at 19% = 1900Column C:C1 =0C2 =B1+C1Use fill down in excel...ie just highlight from C2 down to C500 and click (ctrl-d) and it will autofill in for you. Basically it is counting the amount of items there are up until that pointColumn D:D1 =SUM(B:B)-1Total values (-1 because later we will need a number between 0 and sum-1)Column E:E1 =RANDBETWEEN(0,D1)Picking the random item's numberColumn F:F1 =MATCH(E1,C:C)Match will keep looking for a number that is like this E1 >= CSo F1 now contains the index that will match a prizeColumn G:G1 =INDEX(A:A,F1)Display the prize
This should work (works on mine). You should be able to easily copy and paste...and if you know a bit about excel, it should be easy to follow what is happening. If you need any help (or just want me to give you the excel file, let me know)
