Yes, it's fine as long as it fits. You have to get a LiPo charger for it (for the love of god don't use your Ni-Mh charger with a lipo). Also I would reccomend the LiPo being a hardcase, you'll never know if you crash hard enough and something punctures the battery...
https://linustechtips.com/topic/959972-traxxas-rustler-battery/#findComment-11642691
Thxs yes it is a hard case and i have a traxxas id charger
https://linustechtips.com/topic/959972-traxxas-rustler-battery/#findComment-11663120
If your ESC doesn't have LVCO you should probably add a battery monitor with an audible alert to the list of must haves.  LiPo discharges very differently from NiCad and NiMh batteries...they don't "run down" as they discharge. They run in a narrow voltage margin right up until the battery depletes then the voltage plummets. You don't want to discharge it too far or you risk permanently damaging the battery.
There's no place like ~
Problems and solutions:
FreeNAS
Dell Server 11th gen
ESXI
https://linustechtips.com/topic/959972-traxxas-rustler-battery/#findComment-11663129
The esc in traxxas's current veichles have a cutoff at 3.2v or 3.4v. If that is too low for your taste you can always throw in a lipo low voltage beeper and  set it to more comfortable voltages like 3.6
https://linustechtips.com/topic/959972-traxxas-rustler-battery/#findComment-11663350
That is pretty low...but if you're on it while driving the RC car (high throttle), the voltage cutoff shouldn't be too bad. Toward the end of discharge the LiPo battery voltage will plummet under load but will rise back up a bit when no longer under load. Even if it is 3.2V per cell, it should raise back up when no longer under a load.
I'm pretty careful with my batteries. I typically charge them at 1C, don't take them under 3.7V (resting) per cell if I can help it, and they last a very long time. I also charge or discharge them to 3.85V if I plan to store them for more than a few weeks.
FreeNAS
ESXI
https://linustechtips.com/topic/959972-traxxas-rustler-battery/#findComment-11666679
