I will be getting a new 1 tb hard drive soon and I am wondering how to go about testing the drive to see if it will fail prematurely, so I know not to put any data on it.
Are there any programs and/or methods to test a hard drive?
How do you go about testing a new hard drive?
Thanks
https://linustechtips.com/topic/95944-hard-drive-burn-in/
I wouldn't mate, you test it that way and it'll probably fail prematurely anyway
I've never heard of 'burning a hard drive in' before.
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
https://linustechtips.com/topic/95944-hard-drive-burn-in/#findComment-1284241
If you backup, that shouldn't be of concern. Just install the harddrive and use it as normal.
https://linustechtips.com/topic/95944-hard-drive-burn-in/#findComment-1284242
Thanks
There's almost no way to detect how long a drive will last if it's fresh out of the box. It generally just happens. Though usually a degradation of write/read speeds over time can be an indication.
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
https://linustechtips.com/topic/95944-hard-drive-burn-in/#findComment-1285309
Wow,this is the first time I'm hearing a HDD 'burn in'..I wonder what else pc components that need a 'burn in'..
OP,if it works the first time,then it's all good. If not, then throw it into the sea. LOL
/jk. Go back and exchange that sucker hdd. :D
https://linustechtips.com/topic/95944-hard-drive-burn-in/#findComment-1297102
