So Corsair has two set of RGB fans. The CO-9050061-WW and the CO-9050072-WW. There is about $30 price difference in the US so I would like to know what is different about them. Please let me know
Main PC
i5-9400f @2.9GHz | Corsair H100i Elite Capellix |Gigabyte RGB GTX1060 6GB | Corsair CX650M | Island Professional 120GB SSD | Toshiba 2TB HDD | Corsair Vengeance RGB Pro 2x16 DDR4 3200MHz  | Corsair iCUE 220T | Windows 10 Pro | CPU R20 Cinebench Score -  pts | OpenGL FPS -  FPS | Novabench Score (OC) -  Base -
Keyboard and Mouse
Corsair K70 RGB MK.2 Cherry Mx Red | Corsair Glaive RGB
Streaming PC (HP Compaq 8100 SFF)
Xeon X3440 @2.53GHz | Radeon HD 6450 | HP Compaq 240watt PSU | Toshiba 1TB HDD | Samsung 2x4 DDR3 1333MHz | HP Compaq 8100 SFF | Windows 10 Pro | CPU Cinebench Score - 409 cb | OpenGL FPS - 16.77 FPS | Novabench Score (OC) - 991 Base - 938
Keyboard and Mouse
Logitech G413 Silver White LED Romer-G Switch | Old Gateway Mouse
Monitors
AOC - 21.5" IPS LED FHD Model - l2279VWHE | AOC - 24" TN Panel FHD 144hz 1ms Response - Model G2460PF
https://linustechtips.com/topic/959233-difference/
Look at the Specs!
Sometimes these things have more than one fan in the box so its possible that that is the difference but also other things are possible.
Just look at the specs!
Sometimes its not that obvious...
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/959233-difference/#findComment-11636494
First Part number is the Corsair SP fans, the second is the Corsair LL (light loop) fans. The LL have better RGB than the SP. That's it.
https://linustechtips.com/topic/959233-difference/#findComment-11639915
