I just made a pc for my friend using the air cooler included with the ryzen processor and noticed that his temps were about 40 idle while mine, with an H60 aio, idle temps are in the 50s. Why is this?
CPU- Ryzen 9 3900x
CPU Cooler- Artic Liquid Freezer 2 240mm
GPU-  GIGABYTE AORUS GeForce RTX 3070 Ti Master 8G
RAM- CORSAIR VENGEANCE RGB PRO 32GB 3200Mhz
PSU- Cooler Master MasterWatt 650 Watt
HDD- WD Blue 4TB x2
SSD- 1TB WD Blue SN550 NVMe
Case- Custom Made Desk
Motherboard- ASUS ROG Strix B450-F Gaming
Microphone- Blue Snowball Ice
Headphones- Razer Nari Ultimate
Webcam- Logitech c270
Monitors- MSI Optix MAG24C and Acer KA240HQ Abid
Mouse- Corsair Nightsword RGB
Keyboard- Corsair K95 RGB Platinum MX Speed
https://linustechtips.com/topic/959137-aio-vs-air-cooling-temps/
Just now, airdeano said:
prolly a bad installation mount. the CPU idle should be 5-8° above ambient if at stock speeds. overclocked voltages can make a warmer idle if c-states are reduced or removed.
Thank you, I asked this on reddit and I got like 10 replies just saying that it sucks and I need to get a knew one. I'll make sure to reset it and i'll put some new thermal paste because why not
CPU- Ryzen 9 3900x
HDD- WD Blue 4TB x2
For actual cooling ability per noise such small water pipe coolers are notably worser than "water cooler" marketing hype.
Having water pipe in place of heat pipe doesn't make heat energy magically disappear and it still needs to be dissipated into air.
And such tiny radiator simply doesn't have especially much of surface area, while pump is additional noise source.
Many better heat pipe coolers would beat it in cooling performance per noise performance
But idle CPU state temperatures should be low.
Also might be worth of checking of BIOS settings for CPU voltage are at default.
C-state settings and Windows power management options could also prevent CPU from going to actual idle.
It might also be fan speeds. Higher fan speeds result in lower temps. It might be that your mobo is set to silent mode where it doesn't really spin fans when idle.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
