Cooler Master H500M front panel I/O not working
Solved by kb5zue,
Right off the bat, I can see in the first pic that the PLED+ and PLED- are backwards. As for the power switch, never heard of a reset switch plugging into a separate PCB so I would try plugging the reset switch into the mobo. You have nothing to loose. The reset switch is actually not a "switch" but just a momentary contact button. Also, in the first pic, what are the two wires connected underneath the PLED+ and PLED- wires?
Featured Topics
AtomAlchemist ·
2
eric_s ·
Posted in Power Supplies9 -
1
Silencix ·
Posted in Cases and Mods1 -
8
LambdaBird ·
Posted in General Discussion6
