You might be able to find the ip the TV's talking to by looking in your router logs?
Specs: CPU: AMD Ryzen R7 3700X @4.4Ghz, GPU: Gigabyte RX 5700 XT, RAM: 32 GB (2x 8GB Trident Z Royal + 2x 8GB TForce Vulkan Z) @3000Mhz, Motherboard: ASRock B550m Steel Legend, Storage: 1x WD Black 1Tb NVMe (boot) + 1x Samsung 860 QVO 1Tb SSD (storage), Case: Thermaltake Core V21, Cooler: Noctua NH-D15
https://linustechtips.com/topic/958128-samsung-smart-tv/#findComment-11627635
Set static IP on the TV and don't specify a default gateway.  That will prevent it speaking outside of it's subnet and will stop it going outbound to the internet.
If it doesn't allow you to specify a static IP without a gateway, use 0.0.0.0 in the gateway option and do not set a DNS value.
Please quote or tag me if you need a reply
https://linustechtips.com/topic/958128-samsung-smart-tv/#findComment-11627864
