so i just built my new pc
specs
CPU: RYZEN 7 1800X
GPU: MSI 1070 TI TITANIUM
RAM: 32GB OF DDR4
MOBO: MSI X470 CARBON PRO
And i was wondering why i only get 120 fps on average in csgo with low settings!
i see builds with 1050s and 1060s getting 250+ on high!
i just really need some help
More about : figuring low fps
https://linustechtips.com/topic/957972-need-some-help-with-fps-plz/
Ryzen CPUs perform pretty poorly in CS:GO and other Source engine games thanks to a bug in the engine's code that adds a ton of latency to its code execution on Ryzen based CPUs. Don't ask me for specifics though. Plus the Source engine overwhelmingly favors single-thread performance anyway, which Intel CPUs still remain superior in compared to Ryzen.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
-Moved to PC Gaming-
1 minute ago, espomatt85 said:
But is there anything I could do ?
I see many videos of people building with ryzens and a 1060 and get 250 maxed out settings
they are likely running high frequency memory. Are you?
Desktop benching:
This.
Ryzen CPUs are extremely reliant on memory speeds. Someone running DDR4-2133 RAM will get much less performance in gaming than someone running DDR4-3200. Especially if said DDR4-3200 RAM has optimized timings.
2 minutes ago, espomatt85 said:
32gb ddr4 2400
What timings?
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
4 minutes ago, espomatt85 said:
32gb ddr4 2400
that explains why
Desktop benching:
3 minutes ago, espomatt85 said:
16-16-16-39
Low speed, bad timings; not Ideal for ryzen.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
what explains why?
low frequency and bad memory timings --> worse performance than other setups
Desktop benching:
8 hours ago, espomatt85 said:
aare u sure?
because i dont wanna go buy new ram for it not 2 work :/
Your fps is quite enough for just gaming. Have you already applied commands to unlock fps?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
