i have a define R6 and recently decided to go back to aircooling , so what would be the best aircooler for my 2700x
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/956292-best-cpu-cooler/
Budget?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/956292-best-cpu-cooler/#findComment-11611722
Assuming form the sig you have a custom loop right now some of the best large air coolers would be the NH-D15 and Dark rock Pro 4.
https://linustechtips.com/topic/956292-best-cpu-cooler/#findComment-11611725
5 minutes ago, tp95112 said:
Depends on the budget
4 minutes ago, LienusLateTips said:
Budget?
there isnt per se
im selling my custom loop
im getting rid of the custom loop for aircooling
currently using the stock cooler from my 2700x
https://linustechtips.com/topic/956292-best-cpu-cooler/#findComment-11611738
2 minutes ago, MorganO said:
there isnt per se
Then Noctua NHD15 or if you don't like there brown color scheme go forCryorig r1/ Be Quiet Dark Rock Pro 3/4
https://linustechtips.com/topic/956292-best-cpu-cooler/#findComment-11611744
there isnt per se
Then if your looking to get as close as possible in terms of performance to a custom loop the large dual tower cooler would be your best bet, just double check your clearances around the socket.
https://linustechtips.com/topic/956292-best-cpu-cooler/#findComment-11611751
ordered the dark rock pro 4, hopefully it doesnt block any ram slots
we'll see
https://linustechtips.com/topic/956292-best-cpu-cooler/#findComment-11625667
we'll see
It has over 40mm of clearance if you shift the front fan up or move it around to the back side of the cooler.
https://www.bequiet.com/admin/ImageServer.php?ID=3c506a15636@be-quiet.net&rand=aacb5c72365228152b595775b5d7b78b&lang=1&force=true&download=true&omitPreview=true
https://linustechtips.com/topic/956292-best-cpu-cooler/#findComment-11625716
i read you wont be able to use the closest ram slot to the socket
i have vengance RGB and the crosshair C7H
https://linustechtips.com/topic/956292-best-cpu-cooler/#findComment-11625733
Depends how extra tall they are, the Pro 4 did have a notch cut out the cooler so you can fit the RAM under it. This one has the front fan placed up a little higher.
https://linustechtips.com/topic/956292-best-cpu-cooler/#findComment-11625758
looks like it should fit if the TridentZ does,
no biggie either way as ill just return my ram and buy new sticks
https://linustechtips.com/topic/956292-best-cpu-cooler/#findComment-11625794
