SO many blue screens that I'm seeing red
Solved by ApolloX75,
16 minutes ago, ragepoweredgamer said:Okay. Cinebench crashed and BSOD on the first pass, but I had 35% usage with Chrome alone before I started. Ran again after reboot without Chrome open, no issues.
The randomness is puzzling. Maybe try saving your overclock profile in the BIOS so you can recall the settings and then setting everything back to stock for a test? Or just drop your speed to 4.6. I'm still convinced it's your overclock giving you the errors and crashes at this point until we eliminate it.
