Take a plain paper or a rubber eraser, clean your RAM stick contact point.
Make sure your RAM slot clear from dust before you put it back in.
https://linustechtips.com/topic/1572447-help/#findComment-16428307
I've never heard of paper or eraser being used and I would personally be afraid of debris from the latter. My personal preference is a quality Q-Tip and IPA.
ask me about my homelab
https://linustechtips.com/topic/1572447-help/#findComment-16428351
Question: Is this the computer in your profile? With the 13400f? If so, put the graphics card back in. The 13400f doesn't have integrated graphics.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1572447-help/#findComment-16428501
