Im trying to build a new pc and i cant figure out how to get front fan rgb work out. Light and fans do turn on but is there any way to control the lightning color of fans and is it possible to get them work with asus aura sync?
(I tried to contact CM but it seems like their automated caller attendent have some bugs bc it always 'invalid input' on any option)
Case: CM H500m
Mobo: Maximus X Code
https://linustechtips.com/topic/954796-h500m-fan-lightning-setup/
Case: CM H500m
You should be able to control them with the Addressable RGB strip on the motherboard header. You might need a spliter or some sort of external adapter to get it to
Here's the guide (both of the connections were pre-done). All i did was plug in usb 2.0 cable, rgb cable (it was a 3-pin rgb cable) and sata cable to the board.
Is that what i was supposed to do or am i missing something?
That sounds right, especially if it matches what the photo depicts.
