Hi everyone. I recently built an all used pc. Ever since I installed OS (Windows 10), it keeps randomly freezing, usually while sitting in chrome, but it did happen once just as I logged in. It hasn't frozen at all while gaming or doing something more resource consuming.
My specs:
CPU - i5 750, cooled by a hyper 212 evo, temps at full load below 60C, not overclocked
Mobo - Gigabyte GA-P55-UD3
Ram - Kingston Savage 2400mhz, currently running at 1333mhz, due to low base clock
Psu - Cooler master GX650w 80+bronze
Storage - Radeon R3 120GB ssd, two seagate HDDs 750gb in RAID 0
GPU - Sapphire r9 280x 3gb
OS - Genuine Windows 10 64bit
Nothing is overclocked.
Ty in advance
https://linustechtips.com/topic/954352-random-freezes-while-not-pushing-the-system/
Load motherboard defaults. Update BIOS. seems like a motheboard issue
Main rig: i7 8086K // EVGA Z370 Micro // 16GB Gskill TridentZ 3200Mhz CL14 // Sapphire Pulse RX 7800XT// a variety of noctua cooling // Corsair RM750x v2 //  Fractal Meshify C
Secondary rig: R5 3600 // MSI B450i Gaming Plus // 16GB Gskill FlareX 3200CL14 // MSI GTX 1080ti Gaming X // Cooler Master V650 // Fractal Meshify C
Audio setup: Audient iD4 // Adam A7X // Sennheiser HD 650 // Sennheiser HD 25-II // Audio Technica M50x // Sennheiser Momentum 4
Check to make sure windows is up to date and that all the drivers are up to date first, I have seen a lot of problems fixed by this. A cmos clear could help but keep in mind that if you are using an onboard raid controller like intel rapid storage technology you will have to go back into the bios and change it back to raid mode from ahci
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Redshift)
CPU: Ryzen 7 9800X3DX MOBO: MSI MAG X870E Tomahawk WIFI RAM: G.Skill Flare X5 (2x16gb) 6000MT/s 28-36-36-96 GPU: Sapphire NITRO+ 9070XT, Cooler: Noctua NH-D15 Chromax Storage:  Intel S3520 150gb x4 RAID0 for boot, Crucial P310 4tb x2 RAID0, MSI Spatium M470 1tb, SK Hynix Platinum P41 2tb,  Case: Phanteks Evolv X2 PSU: Seasonic Foucs GX 850W OS: Windows 11 Pro 64 bit
HexOS Server (Vault)
CPU: Xeon E5-2603v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000MT/s 16-18-18-38 GPU: Headless Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 150gb x2 for boot RAID1, x16 in RAIDZ1 for storage, LSI 9305-16i HBA,  Case: Phanteks Enthoo Pro Tempered Glass PSU: EVGA SupeNOVA G1+ 750W
Motherboard has the newest available bios. Windows is fully up to date. There are no drivers for this motherboard on windows 10, so I haven't installed any of them. In device manager everything is detected. I'm pretty sure the bios settings are fine. My raid is connected through the p55 express chipset, and I have disabled the Gigabyte Sata2, just in case.
