Does My card have another slot ?
Solved by DaltonM,
No, there's no PCI slot, just a single ram slot.
https://www.amazon.co.uk/Lenovo-H520e-Desktop-PC-Black/dp/B00KIKPXM2
Look at this review:
QuoteSize: 4 GBI'm writing this review for a friend who unfortunately had to deal with it.
One of the worst PC systems I have ever come across for what it is offering at this price point. It only has 4 USB ports - 2 front and 2 rear - but 2 are taken up by USB keyboard and mouse, leaving only 2 USB ports free! Plug in the webcam, you only have one left, either for printer or usb memory stick.
That's less than what most cheap laptops with its own inbuilt webcam are offering e.g. 3 USB ports.
The case is very nice looking. However, when you open up the case, you will find that in the middle of a vast empty space, there is a tiny squared motherboard with only 1 RAM slot and no PCI slots. I repair and build computers for years and I have never seen anything like it. I will understand if it was fitted inside a very small PC case but Lenovo, seriously?!
1 RAM slot (Yes, just one!) presents a problem - if you want to upgrade in the future, you cannot add more but you would have to buy more expensive 8 GB RAM (currently £65 from Crucial) and put it in the place of 4 GB. It's maximum capacity is only 8 GB while some 'budget' laptops offering a max of 16 GB!! Normally even more for Desktops.
Elsewhere, a £300 laptop would offer you a screen, a battery pack, 2 RAM slots and 3 or 4 unoccupied USB ports. Yet this system without the monitor cannot offer that level of spec for the same price point!! Lenovo is known for making some good laptops but this one is just inexcusable, so pass this one, even if it was to sell for much cheaper.
The last straw came was the network port stopped working within the first couple of weeks of being new, it just disappeared into the thin air and no longer present in Device Manager, nor in Safe Mode. Returned it in an exchange for different but better specced system.
