Hello,
I have a pretty old computer with an i5 - 4570 in it with a stock cooler. Games used to run fine, until for some reason my cpu started reaching 100 degrees celsius and the computer just turned off. I tried cleaning my computer, even disassembling it all, cleaning it, then putting it back together. It didn't help. What do I do? Do I buy some new thermal paste and try to reapply it?
Specs:
intel i5-4570
stock intel cooler
msi r9 280x
16 gb ddr3 ram
https://linustechtips.com/topic/953899-high-temps-on-a-pretty-old-cpu/
Yep do this first.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
If the paste was as old as the CPU then yes, replace it. The stock paste was already kinda poor anyway.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
re apply the thermal paste, and while your doing that also reseat the CPU that might help slightly as well. Also make sure the coolers fan is working (I imagine it is, but you never know)
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
