Updating Build Need Yes Or No
Solved by dizmo,
1 minute ago, distantworld101 said:Because my father is in need of a upgrade as he has a old Am3 that is about to die and i am going to give him the one i have now.
Does he need an upgrade soon? I'd hold off and see if Nvidia releases new cards. Though, that'll be a few month wait.
I'd get a better PSU. G2, or G1+.
Isn't there faster RAM? Every time I look at 3000mhz kits, it's only a couple dollars for higher speeds. Yes, it makes a difference, especially with Ryzen.
Other than that it looks good. You could save money and get the 2700, but if you don't like to manually OC the 2700x is an excellent choice and most find you don't even need to OC it to get the OC results. Gotta love that gen 2 XFR.
