DH57JG not accepting keyboard input during post
Go to solution Solved by Tabs,
4 minutes ago, DrMacintosh said:
I am 90% sure the R9 380 is fine. My RX 580 had the same symptoms as the 380 did when I plugged it in. All the issues seems to have been from the CPU being incompatible.
For what it's worth, "officially" that board will only support up to 87W CPU's - that i7 is a 95W CPU.
Although I know the chipset supports it, Intel could easily have locked that board down to only support i3's and i5's. Here's the official cpu support list for the board: http://processormatch.intel.com/Processors/CompatibleProcessors?componentName=DH57JG
The board has no official support for any kind of quad core CPU; the highest is the i5-661. I'm sorry to say I've never tested it personally but you may need to get a different board if you're set on a quad core.
As in the Title, I've got a Intel DH57JG and during post I am unable to enter the Boot menu options. I should be able to just hit F10 but when I do I get a Beep from the speaker and nothing happens.
Here is a link to the manual for the mobo
https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/desktop-boards/H57_Q57/DH57JG/DH57JG_TechProdSpec.pdf
Laptop: 2019 16" MacBook Pro i7, 512GB, 5300M 4GB, 16GB DDR4 | Phone: iPhone 13 Pro Max 128GB | Wearables: Apple Watch SE | CPU: R5 2600 | Mobo: ASRock B450M Pro4 | RAM: 16GB 2666 | GPU: ASRock RX 5700 8GB | Case: Apple PowerMac G5 | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Be Quiet! Pure Power 11 600W | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Wraith Prism | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2018 Core i3 Mac mini, 128GB SSD, Intel UHD 630, 16GB DDR4 | Storage: OWC Mercury Elite Pro Quad (6TB WD Blue HDD, 12TB Seagate Barracuda, 1TB Crucial SSD, 2TB Seagate Barracuda HDD)
Are you able to get into the bios options with F2?
Current LTT F@H Rank: 98    Score: 2,285,387,178    Stats
Yes, I have 9 monitors.
My main PC (Hybrid Windows 10/Arch Linux):
OS: Arch Linux w/ XFCE DE (VFIO-Patched Kernel) as host OS, windows 10 as guest
CPU: Ryzen 9 3900X w/PBO on (6c 12t for host, 6c 12t for guest)
Cooler: Noctua NH-D15
Mobo: Asus X470-F Gaming
RAM: 32GB G-Skill Ripjaws V @ 3200MHz (12GB for host, 20GB for guest)
GPU: Guest: EVGA RTX 3070 FTW3 ULTRA Host: 2x Radeon HD 8470
PSU: EVGA G2 650W
SSDs: Guest: Samsung 850 evo 120 GB, Samsung 860 evo 1TB Host: Samsung 970 evo 500GB NVME
HDD: Guest: WD Caviar Blue 1 TB
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Other: White LED strip to illuminate the interior. Extra fractal intake fan for positive pressure.
unRAID server (Plex, Windows 10 VM, NAS, Duplicati, game servers):
OS: unRAID 6.11.2
CPU: Ryzen R7 2700x @ Stock
Cooler: Noctua NH-U9S
Mobo: Asus Prime X470-Pro
RAM: 16GB G-Skill Ripjaws V + 16GB Hyperx Fury Black @ stock
GPU: EVGA GTX 1080 FTW2
PSU: EVGA G3 850W
SSD: Samsung 970 evo NVME 250GB, Samsung 860 evo SATA 1TB
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity)
Case: Sillverstone GD08B
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
Details: 12GB ram, GTX 1080, USB card passed through to windows 10 VM. VM's OS drive is the SATA SSD. Rest of resources are for Plex, Duplicati, Spaghettidetective, Nextcloud, and game servers.
I had one of those for a while. Touchy as hell. I eventually just sold off the board because there were too many weird quirks.
Have you checked the BIOS configuration jumper to make sure it's making clean contact? Also, this is going to sound ridiculous but I actually had to do it, if you have some way of connecting a USB to something other than the motherboard USB ports (i.e., a PCIe add-in card or spare front panel USB device with a port on it), it might actually work through there and not the back. Yes, that happened.
Finally, of course, would be going into BIOS and manually changing the boot order. I ended up having to do that more than once because the POST behavior of my board was so, so weird.
Aerocool DS are the best fans you've never tried.
Hypnotoad's RAM is dying, his motherboard is acting like the 6-year-old AsRock it is, a couple of SATA ports have just stopped working, but the RGB remains. The RGB always remains. Hypnotoad lives. All glory to the Hypnotoad.
She just beeps at any keyboard input. The manual says it will beep once very shortly when it is ready to accept input, after that I cant hit a key and nothing happens. If I keep trying or plug in another USB device, it will beep at any key that is pressed.
Are you using a PS/2 keyboard or a USB one?
Have you attempted to clear the CMOS yet?
If the bios has been set to disable legacy usb devices it won't accept input from usb keyboards during POST.
No PS/2 port exists on the board.
Trying to clear CMOS now.
Legacy is disabled as far as I can tell but there is no other way to give keyboard input other than USB
Sorry, didn't check the manual first for the port layout, I was just spitballing. On page 51 of the manual, apparently there's a jumper setting that forces the machine to boot straight to CMOS where you should be able to make whatever changes you need.
Moving the jumper seems to have had no effect
It boots to this screen and just stays there.
 Keyboard not supported by the Motherboard, try a regular old USB keyboard and try again don't use Apple keyboards to enter a bios etc
I've tried it with both my Apple Keybaord and my Logitech G610 Orion. I don't have anything older. After a while either of the two will just make the board beep.
Try just absolutely mashing F2 the entire time, from the point you press the power button, assuming the jumper is now in the configuration mode position suggested on page 51 of the manual (pins 2 and 3)
Also, sorry to say it, but do you have another keyboard you could test it with?
If this doesn't work, it's possible you may have luck by reflashing the bios using recovery mode. This is done by removing the jumper entirely, downloading the latest bios file (https://downloadcenter.intel.com/download/20583/BIOS-Update-JGIBX10J-86A-), and placing the *.bio file on an otherwise blank, FAT32 formatted USB flash drive. The recovery process should be automatic.
Edit: it took me ages to get the right bios link so I started writing this before someone else suggested another keyboard and you replied. I'd recommend trying the recovery option now, assuming you have a space USB flash drive lying around you don't mind formatting for it.
Edit2: here's the official guidance instructions in case you need it, but it's basically "download the file to usb, make sure jumper is removed and boot the machine with it connected and wait for 5 mins. https://www.intel.com/content/www/us/en/support/articles/000005630/boards-and-kits.html?wapkw=bios+recovery
Edited by Tabs
Buy or borrow a keyboard from a friend or nabour must be an OLD usb keyboard
I believe that when the system detects no boot drive it goes into configuration mode. The screen is the same if the jumper is on either set of pins.
I'm trying to source one, but I don't have anything older than my G610 Orion other than my 2011 Apple Keyboard which was in the video.
I updated my post after you posted about that, I was looking into it on the intel site. Try the suggestion I mentioned in my edit and see if it improves the situation - 0663 is the newest bios for the board you have, from roughly 2011.
removed the jumper and am installing the BIOS now.
Good luck mate.
Good luck mate.
Not sure what to look for when its done but you said wait about 5min so I will.
Good luck mate.
Also this is why I love and hate PCs. This is more annoying because this rig is not for me, its for my friend.
When you work in repair, you only ever see them at their worst. I see terrible computers all the time, and outside of outright hardware failures, I can almost always point the finger at the user for mistreating their machine.
Not that I ever tell them that of course.
Looks like I'm supposed to get a screen like this?
But all I see is this:
And what is with the 5A in the bottom right?
Yeah, its been unchanging on that screen since I said I was starting the BIOS update.
<snip>
<snip>
Give it 10 mins at least; the guide was updated last year, but this is an older board. This is meant to be a failsafe recovery method that works even if the BIOS chip on the board is completely blank, but I still don't want you left with a board in a worse state than it was in when you got it.
After 15-20 minutes, if nothing has changed, restart the machine and try going into the bios again - or re-attempt the recovery process if nothing else works.
According to Intel https://www.intel.com/content/www/us/en/support/articles/000005500/boards-and-kits.html
5A means "Resetting PATA/SATA bus and all devices".
Are any cd/dvd drives or hard disks connected to the board right now? If there are any hard disks, have they been checked for consistency on a known-working machine? Any other non-essential devices?
Try disconnecting any SATA/PATA devices and see if the POST code changes.
Edit: Also worth noting that apparently Intel boards will go to keyboard detection directly after post code 5A (above). Perhaps the machine has a bad SATA port or hard drive?
Edited by Tabs
More info
The system had been sitting doing nothing for a solid 30min so I shut it down.
Turned it on after unplugging the HDD and I still have the same screen I posted a pic of.
Is it still stuck at Post Code 5A as well? Did you also remember to reconnect the jumper and remove the USB stick?
Just realised I didn't even mention you should try that. My bad. Try it now if you can.
Edited by Tabs
