Enough Power?
Go to solution Solved by Streetguru,
7 minutes ago, AirSocial said:
Will a EVGA 450 BT be able to power my PC with a i3-8100 and a RX 570? I also have a keyboard, mouse, a lot of case fans, rgb strip, and a bunch of other stuff
Just don't heavily overclock it and run furmark and you should be fine
gaming load is probably 300W max
Main PC
i5-9400f @2.9GHz | Corsair H100i Elite Capellix |Gigabyte RGB GTX1060 6GB | Corsair CX650M | Island Professional 120GB SSD | Toshiba 2TB HDD | Corsair Vengeance RGB Pro 2x16 DDR4 3200MHz  | Corsair iCUE 220T | Windows 10 Pro | CPU R20 Cinebench Score -  pts | OpenGL FPS -  FPS | Novabench Score (OC) -  Base -
Keyboard and Mouse
Corsair K70 RGB MK.2 Cherry Mx Red | Corsair Glaive RGB
Streaming PC (HP Compaq 8100 SFF)
Xeon X3440 @2.53GHz | Radeon HD 6450 | HP Compaq 240watt PSU | Toshiba 1TB HDD | Samsung 2x4 DDR3 1333MHz | HP Compaq 8100 SFF | Windows 10 Pro | CPU Cinebench Score - 409 cb | OpenGL FPS - 16.77 FPS | Novabench Score (OC) - 991 Base - 938
Keyboard and Mouse
Logitech G413 Silver White LED Romer-G Switch | Old Gateway Mouse
Monitors
AOC - 21.5" IPS LED FHD Model - l2279VWHE | AOC - 24" TN Panel FHD 144hz 1ms Response - Model G2460PF
https://linustechtips.com/topic/951832-enough-power/
Should be.
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/951832-enough-power/#findComment-11571237
Just now, Br3tt96 said:
Should be.
Alrighty, Thanks!
Main PC
Keyboard and Mouse
Keyboard and Mouse
Monitors
https://linustechtips.com/topic/951832-enough-power/#findComment-11571240
https://linustechtips.com/topic/951832-enough-power/#findComment-11571263
I have a 2666MHz kit of ram that I OC to 2400 from 2133. Thats the only overcloaking Il be doing.
Main PC
Keyboard and Mouse
Keyboard and Mouse
Monitors
https://linustechtips.com/topic/951832-enough-power/#findComment-11572081
The 450BT is that like 20 dollar EVGA unit, right?
I'd not power a system that has a dGPU that requires VGA connections, but that's just me.
https://linustechtips.com/topic/951832-enough-power/#findComment-11572472
Its actually like a $50 unit. And what do you mean I wouldn't power it?
Main PC
Keyboard and Mouse
Keyboard and Mouse
Monitors
https://linustechtips.com/topic/951832-enough-power/#findComment-11572522
Ah, well I did some Googling. At around the time it came out it was about 25 dollars with discounts. Looks like it's back at MSRP.
It's probably fine but I just wouldn't buy it.
https://linustechtips.com/topic/951832-enough-power/#findComment-11572613
I have it... Im sorry and its what I wanted. I didnt ask for input on the PSU I had I wanted input to see if it would be enough to power. Thats all I wanted to know.
Main PC
Keyboard and Mouse
Keyboard and Mouse
Monitors
https://linustechtips.com/topic/951832-enough-power/#findComment-11572616
