You should be getting around 60 FPS in R6S at 1080p Ultra.
What are GPU and CPU temperatures under gaming load?
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/951795-low-fps-on-r6s/#findComment-11570865
14 minutes ago, Hiivapirjo said:
Hi , my fps is very low like 40-50 at r6s ultra settings. If i try to put them to low fps is about 70. My specs are i5 8600k 1060 6gb and 16 gb 3200mhz ram so whats the problem
What happens when you put the settings to the lowest?
https://linustechtips.com/topic/951795-low-fps-on-r6s/#findComment-11570922
18 minutes ago, Hiivapirjo said:
fps goes up like 60-70
Well, reinstalling windows is the quickest solution to software issues.
Are you running single channel memory?
https://linustechtips.com/topic/951795-low-fps-on-r6s/#findComment-11573096
R6 is my main game, The gpu part lies to you. I have a 1050ti i5-7400 8gb ddr4 and I run low around 50-70 fps on 1080p and when I lower the res I get way over 100. So my thoughts try a lower res if your trying to push a 1060 full ultra.
        Current PC
CPU: I5-7400
GPU: Gigabyte 1050Ti
RAM: Crucial DDR4 8GB 2133mhz
CASE: GameMax Falcon
MOBO: Prime B250M-A
                                       Peripherals
Mouse: Corsair Sabre
Keyboard: Corsair Strafe
Mic/headphone: Blue Yeti /w JVC HA-SR50X
Mouse Mat: Razer Goliathus
https://linustechtips.com/topic/951795-low-fps-on-r6s/#findComment-11576086
Try 1440x900 and work your way down/up
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
https://linustechtips.com/topic/951795-low-fps-on-r6s/#findComment-11576089
Hey man, I think it is the servers. I have been getting low FPS and lag on Siege as well for no reason, this started yesterday. If you are like me and Siege was running fine before then I would wait for ubisoft to fix servers or try updating graphics drivers.
https://linustechtips.com/topic/951795-low-fps-on-r6s/#findComment-11577542
