Even though i have used every single software to stresstest an I7 8700 but at the result i can not reach 4.6 ghz
This is weird because on Intel's home page , i can see that this 8700 can reach 4,6 with turbo
P.s : sorry for the grammar xD i'm not really good at english
37727485_882513481934705_861208932180295680_o.jpg.cdac27f10f50ff71bc15f59e7e24bcff.jpg
https://linustechtips.com/topic/951613-problem-of-8700/
The 4.6 turbo only applies to 1 core, not to all 6. The all core turbo is 4.3GHz. If you want 4.6GHz, you need to upgrade to the 8700K and overclock it to 4.6 on all cores.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/951613-problem-of-8700/#findComment-11569103
