My desktop at the moment is rather old (Using 3rd gen i7 and DDR3 RAM old) and due to real life (i have a full time job plus looking after my own property) i don't have time to really keep up to date with all the component releases that have happened in recent years
As i'm planing on upgrading my machine i need to do some research into components, now i can re-use a lot from my current build
I'll re-use
- Storage (128GB SSD and a 2TB HDD)
- GPU (GTX 1050Ti)
- PSU (700W can't remember brand however)
Because i'm thinking of going Ryzen i won't be able to use my cooler
My budget is around £600 for the following
- Motherboard
- CPU
- RAM
- Cooler
- Maybe a new case
For my case i don't need a tempered glass side panel as my machine is placed in a hole in my desk
EDIT: Will mainly be using for gaming with the odd bit of video editing/workstation work (I sometimes work from home; work as IT Support)
Any suggestions would be great
https://linustechtips.com/topic/949914-need-help-choosing-parts/
any sites to look for, or your country?
Desktop benching:
Well in the UK (Where i'm from) i only really trust places like Amazon and Ebuyer no idea what Newegg is like for UK as i'd never even heard of them till i watched Linus's videos
Don't wanna go EBay for obvious reasons, plus second hand market isn't that big here
What CPU cooler is that? Ryzen isnt the best for you, as it needs expensive memory just to compete with Coffee Lake while still losing out in games (by quite a lot) and only win in parts (not all) of video editing, something you do much less.
Other stores included
PCPartPicker part list: https://uk.pcpartpicker.com/list/hRCmnn
Price breakdown by merchant: https://uk.pcpartpicker.com/list/hRCmnn/by_merchant/
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  (£308.40 @ Aria PC)
Motherboard: ASRock - Fatal1ty Z370 Gaming K6 ATX LGA1151 Motherboard  (£135.66 @ SmartTeck.co.uk)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-2400 Memory  (£134.99 @ Amazon UK)
Total: £579.05
Generated by PCPartPicker 2018-07-20 16:19 BST+0100
Only Amazon (ebuyer stuff just cost more)
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  (£313.00 @ Amazon UK)
Motherboard: ASRock - Fatal1ty Z370 Gaming K6 ATX LGA1151 Motherboard  (£137.36 @ Amazon UK)
Total: £585.35
Generated by PCPartPicker 2018-07-20 16:26 BST+0100
What do you not like about your current case?
Desktop benching:
Total: £579.05
Total: £585.35
I don't know what cooler i currently have, it does me fine if i'm to go with Intel i might be able to save on a cooler as well. Only thing i don't like about my case is that i've had it a little while
