Hi guys!
I'm planning to build my first PC at the end of this Summer. I'm not exactly sure how to put my PCPartPicker list on here, so, I'll just attach a screenshot of it.
Is there any advice/parts to change to make it more accommodating for a new PC Builder?
Please note, that I already have a One Terabyte Samsung 860 Evo that I'm planning to use as a boot drive.
https://linustechtips.com/topic/949708-building-my-first-pc/
The PSU is a bit overkill, a decent 500-600W psu is more than enough.
The supernova G3 is a good one tho.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/949708-building-my-first-pc/#findComment-11552898
It's a nicely-balanced build, I like your case choice. :)
Some advice if you're getting the Cryorig H7, make sure to put it on before you put the motherboard in the case, you can watch the Cryorig H7 install video from Cryorig on YouTube and follow them from there.
Happy building! :D
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/949708-building-my-first-pc/#findComment-11552901
