Its been months since my hard drive has started giving issues.
1. Every time I boot up my PC, I get this error in the notification area - Scan to Repair Drive Errors.
2. It happened twice that after the chkdsk repair utility was executed, the files on my hard drive disappeared yet consuming space on the hard drive.
3. I had to run a data recovery software in order to recover those files. On research, I found that the files disappeared because of the chkdsk utility.
The problem keeps arising although the S.M.A.R.T. status of my drive shows "Good" (used Speccy)
I don't know if my HDD is about to die.
The solution to this problem will be very much appreciated.
Respect.
- Sarvesh K.
This sounds like data corruption, not necessarily hardware failure. For example, a cause of this could be improper shutdown.
Still, backup anything important. Try downloading the disk manufacturer's diagnostic tool and running that. Do an extended read test which could take some hours.
One more thing in SMART, look for reallocated sector count, or pending sector count. If either of these are non-zero, the disk is going bad. It is possible for these to be non-zero and report as SMART good because the drives are supposed to self-repair, but this isn't reliable or safe any more.
