Hi All,
I need recommendation for a small laptop, mostly for work (ms. office, email, and browsing). I was looking at Dell Latitude 3189 or Inspiron 3179.
What's the difference between those 2? which one better? maybe you guys can share your experience using Dell laptops.
https://linustechtips.com/topic/949113-small-laptop-recommendation/
What's your budget for this small laptop exactly? Perhaps we can find you something nicer :)
That Latitude is overpriced af for such a small thing, damn. You can get something muuuch better for €500-ish.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
I wouldn't get either of those personally. What's your budget and where are you located? Do you want a 2 in 1?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
44 minutes ago, cjtaxi said:
My budget was something around 500-600 USD. I dont mind the small size since i usually travel when i work. The most important requirement for me is SSD storage since i think it would help my daily task greatly
Preferred weight and display size?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
4 hours ago, cjtaxi said:
Hi All,
one of the souped up chromebooks hp chromebook 13? Surface go with 8gb ram and 128gb storage?
21 minutes ago, cjtaxi said:
in my country
Which country?
Desktop specs:
12 minutes ago, cjtaxi said:
Indonesia bro, surface here is kinda expensive
Any links of online stores? Also what's your budget in rupiah?
Desktop specs:
Hmm it seems like used/refurb laptop is better
Desktop specs:
