I have hArd drive, case ,monitor, speakers just need to get new psu, ram , cpu , motherboard.
https://www.amazon.co.uk/gp/aw/ls/ref=mw_dp_wl_v?&lid=CE5MRCE0LUN3&ty=wishlist&tag=linustechtips-21
Getting 2 ram packs not 1
Thanks
Please quote or tag  @Ben17 if you want to see a reply.
If I don't reply it's probly because I am in a different time zone or haven't seen your message yet but I will reply when I see it ?
https://linustechtips.com/topic/947975-do-these-parts-work-together/
yes, those should work just fine. Since you already have a case, just make sure its an ATX style and not mATX.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Thanks the case i have is a atx form facter also getting that board to make it able to be upgraded in the future.
Changing psu as dont trust current one at all no brand psu
Will upgrade ram in future when prices drop. Not planning to do gaming on it just upgrading to a platform as was using an older generation intel socket before (1155 socket intel pentium g620) not sure what went wrong with board or cpu.
Should i upgrade the cooler that comes with cpu
4 hours ago, GoldenLag said:
Yes, but i wouldnt pair such an expencive motherboard with that cheaper CPU.
And ASrock PRO4 AB350 motherboard paired woth an 1600 is better value.
Also get 3000 or 3200 mhz DDR4 RAM
Thanks found cheaper ram that is 3000mhz on amazon.co.uk
Drop to AM4 board linked below and grab on of the CPUs linked below
Board
https://uk.pcpartpicker.com/product/yBtWGX/asrock-ab350-pro4-atx-am4-motherboard-ab350-pro4
CPUs
https://uk.pcpartpicker.com/product/72wqqs/amd-ryzen-5-1400-32ghz-quad-core-processor-yd1400bbaebox
https://uk.pcpartpicker.com/product/mV98TW/amd-ryzen-5-1600-32ghz-6-core-processor-yd1600bbaebox
They are both better choices in terms of cash. The website links to store to buy them for the cheapest
Getting x370 board as had a good experince with asus in the past. Also getting board to allow for futureproofing/upgrading of compoents. But will still think about b350 board.
Thank you
Thank you
DO NOT go all out on you motherboard and then cheap out on your CPU.  Get a 2600 and a 70 dollar asus prime b350.  WAY better value.
I edit the shit out of my posts.  Refresh before you respond.
would this psu be fine for parts want to allow extra wattage for future
https://www.amazon.co.uk/hz/wishlist/ls/258A38R37OKZR?&sort=default
if you are going for a 2000 serie ryzen, get a x470 board then aswell, better preformance and features
Thanks
Get a 2x8GB memory kit. There is no performance difference between 4x4GB and 2x8GB. But a two stick kit leaves two memory slots open for a non-replacement memory upgrade should it ever be necessary.
That much wattage is not required. Depending on gpu, a 550W is likely more than enough. Something like a Corsair CX550M or Cooler Master Masterwatt 550W.
i changed the ram in the end so the 2 rams packs bit is not applicable any more should have removed it. just forget to.
mainly getting PSU as is cheaper than corsair at moment for a higher wattage
thanks Ben
thanks Ben
Not the best reason for choosing a psu.
aren't evga and corsair just as good as each other?
Neither company actually makes a psu. Both use various oems. While both for the most part offer above average psu models, some models are better than others.
Thanks I actually never knew that.
Which company would you say to go with then?
thanks Ben
I am trying to keep everything on amazon.co.uk so that i can get the free delivery to the uk and ireland
