I have i5 8600k + GTX 1060 6gb, i used to have 300 fps constant, recently CS:GO had an update and my windows 10 was updated, then the fps i get now is 120 - 150. The Gpu usage is only 27 - 30% at most which doesn't happen when i play PUBG. I get 110 FPS in PUBG, in that case, CS:GO is giving me such pain!! Please if u can help me with this issue! Using every setings at low.
https://linustechtips.com/topic/947303-csgo-low-fps/
Quickest solution to software issues is reinstalling windows.
https://linustechtips.com/topic/947303-csgo-low-fps/#findComment-11530761
Have you tried entering in '-high' into the CSGO launch options? This ensures your PC is giving CSGO the highest priority on the CPU.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/947303-csgo-low-fps/#findComment-11530785
Except when an update kills it again.  (Deferring updates these days are easier said than done)
GameDVR may be the issue too.  If the above doesn't work.  Supposedly it shouldn't be an issue anymore but I'd check:
https://www.pcgamesn.com/how-to-turn-off-gamedvr-windows-10
https://linustechtips.com/topic/947303-csgo-low-fps/#findComment-11530865
  • 1 month later...
Yes, i have given that! but nothing happens for some reason :(
https://linustechtips.com/topic/947303-csgo-low-fps/#findComment-11694920
