my pc build is acting funny and stuttering a lot
By
Scuff
in Troubleshooting
in Troubleshooting
Solved by Spotty,
Install HWInfo64 and check the temperatures on your CPU.
5 minutes ago, JohnDongus said:Is your ram set to the correct speed,also what graphics card.
It's a 2400G so it's possible there isn't a dedicated graphics card. Having the RAM run at the default 2133MHz won't cause noticeable stutters/hangson the desktop, but is otherwise good advice in general.
Featured Topics
halfbood_drag0n ·
8
AcidVinyl ·
Posted in Graphics Cards3 -
Phantasmagoria ·
Posted in Cooling2 -
BotherRed ·
Posted in General Discussion4 -
2
